Elaris Caro ; E-Kastenwagen mit bis 450km Reichweite
arbu
Beitrag von arbu »
Sieht von der Seite verdächtig nach NCV3 aus.
41k netto (nach Abzug der Prämien)
https://news.cision.com/de/elaris-gmbh/ ... w,c3495728
316 BT Kasten L2H1 7G.. 2013
Re: Elaris Caro ; E-Kastenwagen mit bis 450km Reichweite
Da kannst du durchaus Recht haben:
    • 1997: Yaxing-Benz Limited was founded a joint venture between Yaxing Group and Daimler-Benz, consisting of a 50% share-hold for each.
    • 1998.9: Yangzhou Yaxing Motor Coach Co., Ltd was founded by the main initiator- Jiangsu Yaxing Motor Coach Group Ltd with the approval of the Jiangsu government
    • 1999.8: Yangzhou Yaxing Motor Coach Co., Ltd issued 60 million A stocks in Shanghai Security Exchange, entering the Chinese stock market successfully and has become one of a few companies in the national bus industry listed on the Shanghai Security Exchange.
    • 2006.10: Mercedes-Benz transferred its share to Yaxing Group by means of signing a Share Transferring Agreement, and made Yaxing-Benz a wholly owned subsidiary, Yaxing Benz is renamed Yangzhou Yaxing Commercial Vehicle Co., Ltd
    • 2007:Jiangsu Yaxing Motor Coach Group Ltd was renamed Jiangsu Yaxing Automobile Group Ltd. Called Yaxing Automobile Group for short; it includes the following affiliated companies:
      • Yangzhou Yaxing Motor Coach Co., Ltd
      • Yangzhou Yaxing Commercial Vehicle Co., Ltd
      • Yangzhou Diesel Engine Co., Ltd
      • Yangzhou Shengda Special Vehicle Ltd
    • 2007:Yaxing Automobile Group reorganized the bus division of Yaxing, transferring the core business of buses from Yaxing Commercial Vehicle Ltd. to Yaxing Motor Coach Co., Ltd; resulting in a renewed company.
    Den NCV3 findest du auf dieser ASIASTAR Web-Seite ziemlich weit unten in der Bildergalerie wieder. Als Krankenwagen auch bei Yaxing multi-functional commercial vehicles. Im China Car Forum findest du, wenn du die Seite etwas herunter scrollst, ein paar Detailfotos der chinesischen 906-Ausführung. Auf dieser und den folgenden beiden Seiten kannst du dir, wenn du der Sprache und den Schriftzeichen mächtig bist, ein Review mit einer großen Anzahl Bildaufnahmen ansehen.
    Der Auto-Übersetzer zum Testbericht verrät noch folgendes zum Motor:
    Leistung: Dieselleistung, sparsam und effizient
    Der Motor des Modells auf dem Bild ist ein Weichai RA425 High-End Light-Duty-Dieselmotor. Er übernimmt das intelligente, elektronisch gesteuerte Kraftstoffeinspritzsystem von Bosch, das das international fortgeschrittene Niveau darstellt. Die maximale Leistung beträgt 100kW (136Ps), das maximale Drehmoment beträgt 360 Nm, der Gesamtverbrauch auf 100 Kilometer liegt bei etwa 9 Litern und die Emissionen erreichen die Euro V Norm. Darüber hinaus bietet Weichai Euromonitor auch eine reine Elektrofahrzeug-Version an.
    Der Test stammt von 2015. Der RA425 ist inzwischen Geschichte und musste dem RA428 weichen. Ein 2,8L Common Rail Vierzylinder mit SCR und wahlweise mit EGR, DOC und DPF. Der Motor ist mit 110kW und 380Nm oder 120kW Leistung und 420 Nm maximalem Drehmoment lieferbar.
    Als Elektrofahrzeug wurde der AsiaStar Yaxing Wertstar YBL6600BEV6 in dieser Datenbank aufgenommen. Dazu gibt es noch eine Alternative von Rongcheng Huatai Automobile Co., Ltd. Den Hawtai SDH6610BEVWL Electric bus, der dem hiesigen 906 noch etwas ähnlicher aussieht, vermutlich aber ein Umbau war und eine Studie geblieben ist.
    arbu (04 Feb 2022 13:28)
    Quelle: a.xcar.com.cn
    Die Front gefällt mir sehr gut; ausgewogener, gefälliger, moderner, klarer als VW oder MAN und erst Recht die lieblos dahingeklatschte 907/910 Front, die einfach nur nach riesigem, unförmigem grauen Billigplastik aussieht. Für sowas braucht es keine teuren Designer.
    Zuletzt geändert von Exilaltbier am 15 Feb 2022 18:03, insgesamt 5-mal geändert.
    Exilaltbier hat geschrieben: 15 Feb 2022 17:34 Die Front gefällt mir sehr gut; ausgewogener, gefälliger, moderner als die lieblos dahingeklatschte 907/910 Front, die einfach nur nach riesigem, unförmigem grauen Billigplastik aussieht. Für sowas braucht es keine teuren Designer.
    Aber dir ist schon klar, dass der Elaris Caro ein ganz normaler 906 mit anderem Stoßfänger, Scheinwerfer und Kühlergrill ist? Und gerade bei einem chinesischen Produkt nicht von "unförmigem grauen Billigplastik" zu schreiben, finde ich bemerkenswert. Aber auch im Innenraum findest mehr asiatischen Bling-Bling zur Augenverblendung. Da ist mir widerstandsfähiger Grauplastik lieber, der auch mal einen härteren Steinschlag abhält.
    MobilLoewe (01 Jul 2022 10:46)
    Ja, ja...sollten wir mal endlich den Spieß umdrehen und schamlos die Chinaware kopieren.
    Wenn wir die Chinafront dann auch zu Chinapreisen bekommen würden und nicht mit dem MB Feingoldplastik-Aufschlag fürs polnische Hartplastik.
    Auf dem Foto siehts so aus, dass sogar der Kotflügel original 906 ist.
    Vanagaudi (15 Feb 2022 17:45)
    ..auch dazu
    https://www.auto-motor-und-sport.de/ele ... eichweite/
    Da ist man von den Ersatzteilen gar nicht sooo weit weg...
    arbu
    Beitrag von arbu »
    Nun gibt es ein paar mehr Infos vom Hersteller.
    https://www.elaris.eu/caro
    PeterZ
    Beitrag von PeterZ »
    Wenn ich das richtig sehe, hat das Ding ja über 3,5t zGG.
    Leergewicht 3,3t
    Wenn das stimmt, wäre das wohl schon wegen der Führerscheinproblematik tot.....
    PeterZ hat geschrieben: 01 Jul 2022 10:27 Wenn das stimmt, wäre das wohl schon wegen der Führerscheinproblematik tot.....
    Den Führerschein habe ich, wie viele andere auch. Für mich ein 100%tiges Ausschlusskriterium, Made in China kommt nicht in Frage.
    Mein bereits bestelltes E-Auto wird in Europa produziert. Ich weiß, hier geht es um Transporter. :wink:
    Hymer ML-T 570, 4.1t Sprinter 907 4-Matic, 10,25″ MBUX, 9-G-Tronic, OM654 mit 190 PS, Assistenten fast volle Hütte. Big toy... :wink:
    Exilaltbier hat geschrieben: 15 Feb 2022 17:34... und erst Recht die lieblos dahingeklatschte 907/910 Front, die einfach nur nach riesigem, unförmigem grauen Billigplastik aussieht. Für sowas braucht es keine teuren Designer.
    Autsch, das tut weh. :lol:
    Mir gefällt die Front! :wink:
    Exilaltbier (01 Jul 2022 17:47)
    arbu
    Beitrag von arbu »
    PeterZ hat geschrieben: 01 Jul 2022 10:27 Wenn ich das richtig sehe, hat das Ding ja über 3,5t zGG.
    Leergewicht 3,3t
    Mit Führerschein Klasse B, sind mit E-Antrieb bis 4.250 kg für die Güterbeförderung und ohne Anhänger möglich. Eine Ausnahme als Wohnmobil ist wohl noch nicht durch.
    Aber Fahrtenschreiber & Maut werden bestimmt ein Thema.
    https://www.adac.de/verkehr/rund-um-den ... eberblick/
    https://www.promobil.de/ratgeber/3-5-to ... empolimit/
    Folgende Benutzer bedankten sich beim Autor arbu für den Beitrag:
    PeterZ (03 Jul 2022 08:59)
    MobilLoewe hat geschrieben: 01 Jul 2022 10:53
    Die gefällt mir auch und erstrecht wenn auch Nebler/Abbiegelaternen da unten drin sind, aber nicht die leere Grauplastiksparversion. Genau wie an der V-Klasse auch. Da erwarte ich für das Geld mehr Einsatz!
    PeterZ
    [quote=arbu post_id=285141 time=1656685862 user_id=15316
    [/quote]
    Man lernt nie aus. Danke. Allerdings mal wieder eine nicht-EU-deutsche Sonderregelung. Ähnlich wie bei den Simson Mopeds. gilt dann wieder nicht um Ausland....
    PeterZ hat geschrieben: 02 Jul 2022 06:48
    arbu hat geschrieben: 01 Jul 2022 16:31 Mit Führerschein Klasse B, sind mit E-Antrieb bis 4.250 kg für die Güterbeförderung und ohne Anhänger möglich
    Doch doch, du darfst ins Ausland fahren.
    "Der Bundesrat hat auf seiner Sitzung am 07.06.2019 beschlossen, den Spielraum der EU Richtlinie 2018/645 vom 18.04.2018 zu nutzen."
    Der Führerschein B muss mindestens 2 Jahre bereits vorhanden sein. Neuerwerber sind damit ausgenommen.
    PeterZ
    MobilLoewe hat geschrieben: 02 Jul 2022 06:59 du darfst ins Ausland fahren.
    Ich hab ja die passenden Lappen, aber ne, Ausland geht nicht. Siehe unten.
    Da werden wieder viele Leute drauf reinfallen und sich dann wundern, wenn es im Ausland heißt "Fahren ohne passende Fahrerlaubnis", so wie bei den DDR Mopeds.....
    b) Nach Absatz 3a wird folgender Absatz 3b eingefügt:
    „(3b) Die Fahrerlaubnis der Klasse B berechtigt im Inland, sofern der Inhaber diese
    seit mindestens zwei Jahren besitzt, auch zum Führen von Fahrzeugen
    − mit einer Gesamtmasse von mehr als 3.500 kg, jedoch weniger als 4.250 kg
    Folgende Benutzer bedankten sich beim Autor PeterZ für den Beitrag:
    MobilLoewe (03 Jul 2022 00:06)
