Hymer GCS: 2000w Inverter or not?
frederick fitzroy
Re: Hymer GCS: 2000w Inverter or not?
Beitrag von frederick fitzroy »
Alderan55 hat geschrieben: 12 Mär 2025 10:04
frederick fitzroy hat geschrieben: 06 Mär 2025 13:43 Basically, as far as I know, the inverter will be used for the Air-drier and the Nespresso Coffee machine...or I've missed something?
Please advise your thoughts/suggestions
Thank you!
Air-fryer I guess?
If so a 2000W would be at the limit as most of them are 2000W consumption.
What kind of batteries and capacity is installed?
For a 2000W inverter you need really good quality batteries that allow the maximum current the inverter will draw which is around 180 Amps.
Anyhow a converter in my opinion is a useful addition to a RV charging Macbooks and even iOS devices faster than with the 1A USB sockets and what about other things - we - use when we are traveling.
Electric shaver and beard trimmer, electric toothbrushs, battery chargers for camera and drone equipment and many more items.
Best Bernd
Please Apologies: I was meaning Hairdryer :wink:
The Grand Canyon S will have n.2 BOS Battery 80ah each installed directly by HYMER in its Smart Battery System 2.0
https://www.bos-ag.com/products/bos-bat ... Mi4wLjAuMA..
The inverter suggested by the vendor are these, as far as I've understood
Inverter Dometic 2000w https://www.dometic.com/en/outdoor/powe ... 9600002549
Inverter NDS 2000w https://www.ndsenergy.uk/prodotto/smart-in-inverter/
Alderan55
Beitrag von Alderan55 »
Mine has the Dometic and I am very happy with it.
4 years now works flawless and - quiet - only at max power the fan is on but quits fast after the power draw.
Best Bernd
frederick fitzroy
Thank you!
