I'm looking for a rebuild kit for my A9062804000 transfer case, this is on a UK spec 2012 516.
I have a issue with the rear output shaft bearing and seal, which is now worn with about 5mm of play up/down etc. this is causing a vibration in the drive line at 70kmh+. I had a issue with the UJ and central bearing on the rear prop originally, which I think caused wear in the transfer case.
I am a proficient engineer so rebuilding would be easy if I can find the correct parts. I have spoken to Oberaigner and they refuse to help only saying I need to buy a new case from Merc, which is a bit out of budget. I have found second hand ones, but again u never know the history and finding someone in the UK that rebuilds these seems impossible.
Any pointers etc would be helpful. Or do I just start pulling the thing apart and looking for the parts by measuring.
Hopefully someone can help
Lee
ZG3/AR5 Rebuild
Re: ZG3/AR5 Rebuild
Hej,
have a look there:
https://www.sprinter-forum.de/viewtopic ... ergetriebe
He has taken Parts not from MB ...
Regards Andreas
have a look there:
Regards Andreas
Overlandfaction
Re: ZG3/AR5 Rebuild
Thanks for the link, not parts list in the discussion which is a shame.
Regards
Lee
Regards
Lee
Re: ZG3/AR5 Rebuild
Is there a Build /Model Nummer for the Transfercase? Like 711.680 for the TSG360 Manual Gearbox.
Otherwise i can only find this Parts List and Diagram for it: https://mb-teilekatalog.info/view_SubGr ... subgrp=080
